are clear carb bowls for the pwk 35mm available
two-stroke-brit
Post by two-stroke-brit »
hi all,as above .
T I A Mark
She might not be pretty but always a fun ride !
Friedom
Re: are clear carb bowls for the pwk 35mm available
Post by Friedom »
two-stroke-brit wrote:hi all,as above .
T I A Mark
Man that would be cool. Are clear bowls available for ANY carb?
"Good job, guys. "
Tedh98
Post by Tedh98 »
Lectrons are the only carb I have seen with a clear bowl.
Plastic bowls arent without their problems though.
Are you wanting one for the "cool" factor or for setting the float height?
two-stroke-brit
here are some for 30mm PWKs
http://www.ebay.com/itm/OKO-SPARE-PARTS ... B-&vxp=mtr
and in answer to TEDs question a bit of both really.
cheers mark
IDRIDR
Post by IDRIDR »
^ that's cool.
Not a terrible price to pay to check fuel level/float height is spot on. I'd put the metal one back on after checking.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
two-stroke-brit
IDRIDR wrote:^ that's cool.
thats the plan. :grin:
but still cant locate a clear bowl for a 35pwk.
Tedh98
Post by Tedh98 »
The clear bowl isn't going to really help you with setting the float. The fuel level should be 0-2mm above the carb body-bowl mating surface.
This is how I mimicked the factory approach to setting the float: setting float
sarrant
Post by sarrant »
Related, but off-topic. Has anybody else heard/confirmed the rumor that Keihin may be ending production on Airstriker/PWKs?
two-stroke-brit
thanks tedh98 .
I wondered how the home made set up would look/work.
i will make one myself thanks for sharing.
cheers mark
Tyl3r
Post by Tyl3r »
Tedh98 wrote:The clear bowl isn't going to really help you with setting the float. The fuel level should be 0-2mm above the carb body-bowl mating surface.
Nice simple little tool!
Clear fuel line and a couple nipples on 90's from the top and bottom of the float bowl would make an easy to see anytime gauge.
