1994 ktm 300 forks (white power usd) on kdx H
Posted: 09:16 am Aug 10 2016
i should be completed in a couple of weekends. here is the start:
bike 1997 kdx220 (using a 1993 kdx E for mock up)
forks 1994 ktm 300 mxc usd white power form left stamped K23M94US
plan: press out kdx and ktm stems, replacing the ktm stem with a shimmed kdx stem
the ktm forks the same bearings for upper and lower positions, which are skf #332174, and measure 29x50x14 mm.
the kdx forks use upper bearing 25x47x15 mmand lower bearing 33x55x17mm.
at first i pressed the kdx LOWER bearing on to the ktm stem with a 1/2mm piece of shim stock to take up the difference in sizes between the kdx bearing and ktm stem, then slid the forks into the test bikes frame. finally i dropped the stock upper ktm bearing into place, and tapped the upper triple tree into position.
results: the lower bearing is a good fit, but the ktm stem is too short, and also to large an OD to allow for the upper kdx bearing. this means the wider ktm upper bearing is too wide, and doesn't fit the smaller kdx race that is pressed into the kdx frame.
i used .010" brass shim stock wrapped twice around the ktm stem for the test fit. the bearing is snug enough to test. I'll use brass for the final assembly also.
this week i will press out the kdx and ktm stems, then shim the kdx stem fit the ktm triple and press it in to the ktm triple. making up the difference between the kdx bearings and the ktm steering stem will also be brass shim stock.
why these ancient ktm forums, that will require a ktm front wheel/axel/brake caliper that is different from everything Kawasaki/Suzuki/etc makes?
because they are fully adjustable compression/rebound, and i paid forty dollars for them and the rear shock, and they are massive compared to the kdx spindles.
I'll update with pictures after i press things together.
