I have a 2002 Kawasaki KDX220R that started to give problems. First it started losing a lot of the coolant from the overflow tank but I couldn’t tell whether it was overheating or not as it didn’t evaporate the coolant and lately, every time I took it out for a ride; after a couple of hours of use it started to: (a) run rough (like misfiring), then (b) shutting-off repeatedly, and finally (c) it won’t start. So back at home I checked the spark plug, carburetor, air filter… cleaned them, etc. Took the bike out next time… and same story. Finally on my fourth cycle of this… no spark!
And the saga begins… with the help of the previous owner/friend we pulled (i) the stator, (ii) spark-plug-cap, and (iii) the ignition coil out of the bike and - due to the lack of a service manual and immediate advice – dropped them to an electronic shop for they to let us know whether those where ok. However, we didn’t even knew the resistance (ohms) they should have. At the shop they said the stator was ok, but that the ignition coil and cap were toasted. Checked all connectors and cables and they are good. Then I phoned “literally” every single motorcycle shop in the city, plus the three closest cities as well. Parts (either ignition coil, spark plug cap or others) will take 3 weeks to get here. I order the OEM Ignition coil (as apparently that was the trouble). Just FYI, it’s been 4 weeks and the shop say is on back order
Anyhow, I managed to get (i) the electrical section of service manual (thanks to an unknown guy but I still hope to find the entire service-manual somewhere), (ii) a “generic” ignition coil, and (iii) a spark-plug-cap - that seems to match well the spark plug. Apparently any ignition coil as long as it’s grounded to the bike… should/could work. It seems there’s really no clarity about this (???).
Based on the service manual I checked the resistance (primary and secondary) of the ignition coil. The manual says they should be: Primary= 0.16 to 024 Ohms (at 1 Ohm scale) and Secondary= 5.0 to 7.6 (at 1k Ohm scale) – read 5,000 to 7600 Ohms. What I got from the “Generic Ignition Coil” was: Primary= 0.16 Ohms and Secondary= Nothing… Zero, “nada” (???).
Then I went and tested the original CDI unit and the results I got were hit and miss. Some as the specs, some quite different (e.g. infinite when zero or vice versa) and some constant Ohms readings of about 0.35... most likely a Multimeter reading issue.
In the interim of waiting for parts to arrive and regardless of the readings on the “generic ignition coil” I installed it with the existing CDI unit and the generic spark-plug-cap and… Voilà!... the bike started, every time; however, it runs very rough (again, like ignition misfiring).
On my fear that the CDI unit is giving troubles as well, I ordered one + an extra ignition coil from the fellows at regulatorrectifier (http://www.regulatorrectifier.com/catalog ) nice people!. They are way, way cheaper (IC=$40 + CDI=$70) instead of $80 +$450 respectively for OEM parts through dealerships and apparently plug-n-play OEM equivalents (?).I’m still awaiting for the order to arrive. As noted above, I’m still awaiting as well for the OEM-Ign.-Coil from the dealership.
My plan is replace the existing CDI and replace the Ign.-Coil with the OEM (more expensive one) + replace the spark-plug-cap with the OEM which I just got today. I will end up with one additional Ign.-Coil as a spare… and probably donate the generic one (it was $30) to whomever.
Now, questions:
1. Do the different readings in the CDI unit really make a difference and if so… how?
2. How come the Ign.-Coil performance is measured by Ohms, however voltage/amperage/frequency output are disregarded?
3. Different multimeters (digital/analog) give different readings on any of the components… this thing is literally all over the map… so, what device is the 100% right one to be used for testing these components and who has it?
4. Where are the experts about dirt bike electric ignition systems (for older bikes though)?
5. Who can explain this accurately, correctly and on solid ground rather than trial/error or guessing?
Thanks!
