Regular Maintenance?
Posted: 12:50 pm Jun 09 2016
by sammydogjj
What do you all do after your bike has been sitting for a couple months? I drained all the gas, motor oil, and spark arrestor goop. I also cleaned and rebuilt the carb. Anything else I should look at or clean/replace while I'm at it?
Re: Regular Maintenance?
Posted: 02:30 pm Jun 09 2016
by 6 Riders
Grease the stem bearings, if you want to dive in real far, grease the linkage bearings.
Posted: 02:34 pm Jun 09 2016
by sammydogjj
6 Riders wrote:Grease the stem bearings, if you want to dive in real far, grease the linkage bearings.
Thanks!
Posted: 03:26 pm Jun 09 2016
by pumpguy
Wheel bearings and brake pads are also frequently neglected.
Posted: 06:17 pm Jun 09 2016
by sammydogjj
pumpguy wrote:Wheel bearings and brake pads are also frequently neglected.
I replaced those right before I stowed it for the season. Thanks, though!
Posted: 07:47 am Jun 10 2016
by K50X200
After my KDX sits for a couple months I usually roll it out of the garage, turn on the fuel, kick it over once - maybe twice, and go for a ride... :grin:
A couple years would probably be a different procedure involving grease, bearings and brake pads, etc...
Posted: 10:05 am Jun 10 2016
by sammydogjj
K50X200 wrote:After my KDX sits for a couple months I usually roll it out of the garage, turn on the fuel, kick it over once - maybe twice, and go for a ride... :grin:
Yep! I've already ridden it once or twice after it sat for the winter. Overflow issue :(, so I'm still rebuilding the carb and adjusting floats. Hopefully that fixes it and that's the only issue I am aware of.
