Shock shaft interchange
A service reference
bob_jones
Been thanked: 2 times
Post by bob_jones »
What is the likelihood that the shock shaft from a later model kdx would fit the shock on a c-series? I have a corroded shaft on my 1986 and the piston diameter might be the same I wonder if the shaft might interchange. Any ideas?
BillyWillicker
Re: Shock shaft interchange
Post by BillyWillicker »
I ended up not having a good enough shock to work for you. I will keep an eye out. Try Ebay, I lucked out and got my shock from ebay.
bob_jones
Post by bob_jones »
I've beat ebay to death. Got absolutely nothing.
BillyWillicker
I sniped mine with BIN after it was list for like an hour. $56 to the door. Keep looking, one will come up.
Has thanked: 66 times
Been thanked: 20 times
No. You need a 1986 to 1988 shaft. Shocks show up sometimes, so hang in there. 1989 and newer are 44mm bodies are 44 mm, not 40 mm.
bob_jones
Post by bob_jones »
After much frustration, I've sent it off to FRP for re-chrome / rebuild. It was just the best way in this situation. Nothing I found was likely to be much better than what I already have. Thanks for the info.
Well, you know it should be in great shape for a long time now.
bob_jones
Post by bob_jones »
The interwebs say Mr. Fredette knows what he's doing so I guess we're about to find out.
