Help me install KIPS part
Posted: 11:30 pm May 10 2016
I swear this one tiny part 92049 is the bane of my existence. I've had problems with this little oil seal just sticking out a tiny bit and causing friction with the gear 16085. It has happened again, so I want to replace this seal.
The seal is flat on one side, and the other side has a slot between the inner and out diameter. Which side faces in towards the engine? Any other tips or tricks to make sure this is seated properly and not going to interfere with the rotation of the gear?
