Anyways.... pics.... from the beginning
Before....
Came across a great deal on a complete front end on ebay..... they're older, off a 1994 KX-250, but seemed to be in great shape and came with everything
And they were cleeaannnnn...... this was exactly how they came out of the box, no cleaning done
I actually went out and bought a press, just to do this, lol (I had been wanting one for my garage anyways.... good reason to). KDX stem pressed out of the stock clamp
Pressing the KX stem out of the KX clamp
Worked like a champ
KDX stem pressed into the KX clamp..... fit perfectly, nice and tight.... no knurling required
For the little spacer for the top clamp, after trying several different things, I ended up using this..... a 1" nylon bushing (got at Tractor Supply). It fits into the KX upper clamp nice and snug
Then just used the Dremel tool to slowly shave it down to the desired thickness (which is quite thin).... worked like a champ! Fit over the stem nice and snug but easy enough you can easily install and remove it
Test fitting everything
Everything seemed good, so got my tire swapped over from the KDX wheel to the KX wheel, then put on a new 2015 KX-250f front fender and decal, and Core Moto braided brake line (which was a major PITA to bleed out). Prior to this I had already taken the forks apart and replaced the seals, bushings, and fresh fluid, so they were all ready to go
New headlight housing (old one was a little beat up from a few crashes), and new composite hand guards as well..... gotta keep her looking fresh, lol
Next day, first dirt ride with some buddies down at Enoree, SC..... it felt GREAT! Definitely stiffer, but not bad..... way less pogo-ish like the stock forks were, bouncing everywhere
All cleaned up
A few more ride pics..... new look and new feel.... I'm loving it! I ride almost every day with my best friend Scott here and his '06 KX-250
Older picture.... but now to get my supermoto wheels mounted up with the new forks..... can't wait! They were just loose fitted here, as the front axle was too small on the KDX forks
Sorry for so many pics..... I get a little carried away with pictures sometimes, haha. Seriously love this bike though.... and definitely glad I ended up doing the swap
