spoogy 95 200....frustrated
Posted: 09:54 pm Mar 23 2016
by argclh6670
ill try posting this here...my kids 95200 spooges big time! it has lean pilot...it still loads up badly...main seems good....running jd needle (leaner of the two)on #1....runs great when on the pipe....changed jetblock gasket...floats set numerous times...didcthe water test to see if inlet needle was leaking...passed. not sure what else it could be?? any suggestions?
Re: spoogy 95 200....frustrated
Posted: 09:02 am Mar 24 2016
by Tedh98
Leaking crank seal?
Posted: 09:24 am Mar 24 2016
by james
Tedh98 wrote:Leaking crank seal?
which seal?? part no?? 92049/50/51???
Posted: 11:58 am Mar 24 2016
by Tedh98
92049
Posted: 03:00 pm Mar 24 2016
by Jaguar
synthetic or semi-synthetic oil leaves less spooge
Posted: 03:33 pm Mar 24 2016
by argclh6670
running semi syn....did leakdown test, after laat topend....passed. the spooge prob has been around since we got the thing... the bike just drinks rhe fuel too....in a ahort course HS it isnt uncomnon for the son to switch to reserve on last loop.
Posted: 07:02 pm Mar 24 2016
by ohgood
argclh6670 wrote:running semi syn....did leakdown test, after laat topend....passed. the spooge prob has been around since we got the thing... the bike just drinks rhe fuel too....in a ahort course HS it isnt uncomnon for the son to switch to reserve on last loop.
there is a gasket (and oring) under the jet block in the carb. it's a common failure point.
Posted: 07:27 pm Mar 24 2016
by Tedh98
It is the stock carb, correct? What is your elevation and what size main jet?
To be running a 38 pilot and the clip at the first position is awfully lean (unless you ride in high elevations) for the 200. Seems like a lot of extra gas is getting to the engine.
Does gas run out the overflow if you lean the bike at a slight angle?
Do you have any way to swap carbs?
Any chance the jet block gasket shifted out of place when you replaced it?
Posted: 08:22 pm Mar 24 2016
by argclh6670
yeah...stock carb. 155 mj. no fuel leaks out unless of course its all the way over on its side. i wish i had another carb to swap in for testing.
Posted: 08:38 pm Mar 24 2016
by Tedh98
Do you have any non-JD needles to try? I was thinking that maybe the JD needle you are using isn't meant for the KDX. Going back to the stock needle or one of the more common alternatives could shed some light.
Posted: 08:47 pm Mar 24 2016
by argclh6670
i have the stock needle, cel and del....the jd kit is was for the kdx....the kit eorked great for my RMX so i picked pne up for kdx too.
Tedh98 wrote:Do you have any non-JD needles to try? I was thinking that maybe the JD needle you are using isn't meant for the KDX. Going back to the stock needle or one of the more common alternatives could shed some light.
Posted: 08:48 pm Mar 24 2016
by Tedh98
So does it do run poorly and use that much fuel with those other needles?
The JD needles could have been mis-labeled.
I used JD needles years ago on my 200 and was extremely happy with them.
Posted: 08:50 pm Mar 24 2016
by argclh6670
yes it does, even worse. starting to wonder if needle jet seat is worn?
Posted: 09:03 pm Mar 24 2016
by Tedh98
Other than something internally worn or damaged in the carb, the only other thing I can think of is reeds. Were they in good shape when you did the engine work?
Posted: 12:22 pm Mar 26 2016
by Jaguar
the float valve could be letting gasoline past it when it should be closed (due to the float being high enough).
also if the float itself is leaky then it won't be bouyant enough and will let the gas level rise.
