But I got to thinking, if I wanted to use the KDX 250 swingarm I could just buy a 15mm ID x 17mm OD bushing like the one pictured below. Press it into the KX250 frame, use the KDX swingarm bolt, bushings, and swingarm on the KX250 frame. I need to verify the distance between the frame is the same between the KX250 and KDX250 frame along the axis of the swingarm bolt for this to work. But if it did it would allow the use of the KDX250 rear wheel, spacers, and axle I already have.
Just an idea I had this morning as I was headed to work.
Any thoughts or things I haven't considered?
