Mechanical seal help!
Posted: 09:43 pm Feb 23 2016
by waldo177
What are some proven methods of installing this mechanical water pump seal? I just broke the new one and will be ordering another, maybe 2 just in case. Please help
Sent from my SM-S920L using Tapatalk
Re: Mechanical seal help!
Posted: 11:11 pm Feb 23 2016
by bone7615
I'm not sure if this is what your looking for but I hope it helps.
Posted: 07:30 am Feb 24 2016
by waldo177
That's how I broke the new seal the first time, maybe I need to search for a different socket like a thin wall because the bigger socket I have will not fit down in the tight spot to get it seated
Posted: 09:40 am Feb 24 2016
by david
You don't want to push on the carbon or the ceramic pieces with anything hard and you have to use steady, even pressure. No shock loads. We have seals like that for 2.5" and 3.0" shafts here at work that cost up to $1500. Gota be real careful putting them in. I would see if you can find a small piece of PVC pipe or plastic tube that you could use as a 'push stick', not a metal socket.
Posted: 09:54 am Feb 24 2016
by waldo177
Thanks I will try that good idea. If I can find some that will slide over the ceramic end to be able to get to the metal cup
Posted: 10:43 am Feb 24 2016
by david
You definitely only want to press on the metal cup, NOT on the carbon element, those are SUPER brittle.
Posted: 05:16 pm Feb 24 2016
by waldo177
That's what I thought I was doing but my socket I guess was touching more of the ceramic end than I thought. It's a very tight space on that cover to get into.
Posted: 12:55 am Mar 06 2016
by Ffryno13
Any luck on the install, im having the same issue right now. Also is there another oil seal between the mechanical seal and the sealed bearing?
Posted: 11:58 am Mar 06 2016
by Tedh98
Ffryno13 wrote:Also is there another oil seal between the mechanical seal and the sealed bearing?
Yes. On an H series at least.
Posted: 12:21 pm Mar 06 2016
by Ffryno13
OK so I found the oil seal behind the bearing. My next question is on the sealed bearing does the seal go to the oil or the water?
Posted: 12:32 pm Mar 06 2016
by Tedh98
Ffryno13 wrote:OK so I found the oil seal behind the bearing. My next question is on the sealed bearing does the seal go to the oil or the water?
I am assuming mine has never been replaced and the seal is to the water. I think that makes sense as the bearing would then have lubrication.
Posted: 12:40 pm Mar 06 2016
by Ffryno13
That's what I was thinking but I thought I read somewhere that seal went to the oil, the sealed bearing does have grease in it....I'll have to flip that around... And since that is true I can assume the oil seal would have the flat side to the water.
Posted: 09:27 am Mar 12 2016
by waldo177
That is the way I installed the oil seal was the flat side towards the water. But I also pointed the sealed half of the bearing towards the water as well
Posted: 01:29 pm Mar 12 2016
by Ffryno13
I found a peice of conduit at work that is pretty close to the right od/id of the mechanical seal so I can install the new one when it comes in next week... I hate waiting
