So I'm working into my front end swap on my 92 200. Have a rm250 front end with 49mm Showas just about ready to go.
But when I was cleaning up the "custom" paint job on the plastics, I noticed that a PO had a "K" sticker and an "X" sticker, with no indication that there was a "D" in the middle. Suddenly I'm wondering if I already have KX forks?
How do I identify them if I do?
Sent from my SM-G900V using Tapatalk
Identifying kx forks
Friedom
- Tedh98
sarrant
Conventionals?
Really, there's only two years of KX conventionals that somebody would take the effort to swap onto a '92 KDX. Prior to '88 all KX forks were similar (or inferior) to the conventionals used on E-Series KDX. So those aren't a likely swap.
The '88 cartridge KYB KX forks are somewhat similar to the later H-series KDX forks and represent an improvement in tunability and high-velocity valving over the '89-92 KDX damping rod forks. The '89 KX 46mm conventionals are a more advanced fully adjustable design and often considered (along with the RM front end you have) as some of the most-favored conventional forks ever put on a dirt bike.
Any KX forks would be easy to visually differentiate from E-Series conventionals, as the MX forks have a clamp-on axle type instead of the pull-through (quick change) type that the KDXs came with.
Friedom
Re: Identifying kx forks
That tells me enough, thanks.
I should have posted a pic with my question, but camera is on the fritz.
I noticed that there is no rebound damping adjuster on the forks it came with and assumed stock from there. Thank you.
