Cylinder opinions
MarioM3
Cylinder opinions
Post by MarioM3 »
I just pulled my 220 cylinder, piston/cylinder show no deep scratches and appear to be in decent shape. However the cylinder walls show a lot of glazing and no visible cross hatching can be seen, pictures:Image
There also can be seen on the jug (under Reed) to read 3/12 (in pink on left) and I don't know what the other says (in green on right), picture: Image
I would like some input and opinions if this is normal, and I can scuff it up with oil and scotchbrite pad. Or will this require more in-depth repairs (plating)?
Thanks,
Mario
6 Riders
Re: Cylinder opinions
Post by 6 Riders »
Plate it! Can't go wrong and will last for years. Plating (nikaseal) is better than the Electroplating that Kawi put on these cylinders to begin with.
It looks like the factory plating may be worn thin in a few places. It is hard to tell without scrubbing the glazing off though. Try scotchbrite pad and some lubriation, then wash it well and post up another pic.
MarioM3
Cylinder opinions
Post by MarioM3 »
Thanks for the help so far guys! I just used a green scotchbrite pad and premix and scrubbed the walls. Here are the after pictures: Image
Thanks,
Mario
MarioM3
Cylinder opinions
Post by MarioM3 »
More from top view:
Jaguar
Country: Ecuador
Post by Jaguar »
why would you worry about it glazing? that just means the rings have matched the cylinder and it is sealing good. scratching it up is only for when you install new rings so they will wear in to match the cylinder.
MarioM3
Cylinder opinions
Post by MarioM3 »
I thought that glazing was a sign for the cylinder wall coating getting thin. But that's good news then, thanks.
Mario
Bitteeinit
Post by Bitteeinit »
How does the typical nikasil replated cylinder last? How many pistons could it handle (provided you change them regularly) before it wears out?
Sent from my ASUS_Z00AD using Tapatalk
Worn? Yes.
Worn out? No.
Where exactly in the middle? It depends on who you ask.
What are you using the bike for?
Can you afford a new piston kit and plating or are you on here asking for a majority to comment and tell you not to spend the money? (it happens a fair amount)
Depending on how often you ride, how hard you ride, etc., it might be a candidate for "ride it one more year" then replate it next winter.
6 Riders
Post by 6 Riders »
I could let that go one more year with new rings, but only if I could afford to do the plating. The last "piston slap" i did was on my son's 220, just to get the stock piston out of it. This summer I have my 200 getting an EG 225 kit and a new left hand case, which means full rebuild. IF I can afford it, the 220 will get replated and a new piston.
Tyl3r
Post by Tyl3r »
Lots of good info here from you guys that have been around the block a couple of times. :pop:
About how much could one expect to pay for Millennium Technologies to re-plate a KDX cylinder?
Also, do you think it would be a good/bad idea to send the KIPS out to them also for their power valve service? I haven't tore into the KIPS yet, so I didn't know if it was worth the $50 bucks to pay them, or if I should just do it myself? I'd like to learn and do it myself, but it would be nice to have a pro do it right the first time...
To the OP - Not trying to post jack or anything, I figured these questions would go along with the theme of this thread, rather than making another
6 Riders
Post by 6 Riders »
I paid $450 for replate, piston kit, top end kit. Did the Kips myself, it sucked. I went through a local shop to get this done. If you go through Millennium Tech yourself and source your piston yourself, it could be cheaper.
MarioM3
Cylinder opinions
Post by MarioM3 »
Okay, thanks for the info. The cylinder is packed up and getting shipped to millennium. The head is getting shipped to RB. I figure I would do it now since I have the time/money. I took the kips out myself, it really is not that bad at all. I just wanted everything super clean. I already have a new piston/rings and sourced all oem gaskets.
Thanks,
Mario
Tyl3r
Post by Tyl3r »
Nice. Do you mind sharing an approximate cost for the replating alone? I did some more reading on taking the KIPS apart, you are right, it does not seem that bad. I think I will give that a try also.
MarioM3
Cylinder opinions
Post by MarioM3 »
Yep, I didn't email or call ahead. I printed out there form and filled it out, I checked call with estimate. So when they call, I will let you know.
Tedh98
Post by Tedh98 »
Tyl3r wrote:Nice. Do you mind sharing an approximate cost for the replating alone?
I believe that most of the platers list prices on their sites. I know powerseal does.
Tyl3r
Post by Tyl3r »
Everyone just talks a lot about Millennium, so I was really curious to see what they charged. I checked their site, just gives info, no price. It probably depends on the size and condition of the cylinder.
Tedh98
Post by Tedh98 »
Tyl3r wrote: I checked their site, just gives info, no price.
A link to their pricing is on the main page
http://www.mt-llc.com/pricing.php
Tyl3r
Post by Tyl3r »
Tedh98 wrote: A link to their pricing is on the main page
Dang, I can't believe I missed that... thanks!
Cylinder opinions
MarioM3 wrote:The cylinder is packed up and getting shipped to millennium.
You are sending the new piston with it, yes?
