wheel alignment on forks HELP
I need help, staff the front wheel of my KDX 98 not this well aligned in the middle of forks , it seems to be but near to the brake calipers anyone can help???
- kawagumby
If the brake rotor and pads are centered in the caliper you're good to go, if not, you may have an axle spacer issue.
how i fix that?
can anyone post a pics from the wheel on the forks?
- kawagumby
Get the right spacers... no doubt you can get some cheap from ebay for your bike....or cut/shim the spacers you have to fit correctly (center the rotor in the caliper).
- Tyl3r
Re: wheel alignment on forks HELP
Switch around your wheel spacers and try again
Maybe the two spacers are different lengths and they got mixed up? I've been playing with KX's lately, I forget what the spacers look like on the KDX wheels. I would think they would be different lengths though because of the odometer on the one side
- 6 Riders
Only one spacer on the kdx, brake side. The non-brake side has the gear drive on it that acts as the spacer.
- Tyl3r
Cool. Well, he said his wheel was over to the brake side...maybe he just put the spacer on the gear side, rather than the brake side?
