92' Cylinder Exhaust Fitment
Posted: 05:40 pm Dec 22 2015
Good evening,
I recently picked up an E series basket case. When I removed the cylinder I found it badly damaged. The KIPS valves were absolutely decimated. One gear section has rattled around in there so long it looks like an egg sinker. The bores that accepted the valves were badly worn also. Luckily! I found a serviceable cylinder on EBay. Photos looked good, I double checked the parts schematic, same part # in 89' which is the year this is off of so I jumped on it. I received it today to find I had ignorantly missed one glaring difference.
One other minor difference. This hard plastic "keeper" that rests on top of the valve pucks.
I measured the ports. Everything appears identical. When I search the part number 11005-1585 I only get European, Japanese, and Australian results. The other cylinder has the 1569 as expected.
I bought the part out of Florida from an outfit that appears to part lots of bikes. They even had a photo of the rest of the bike. It had black plastics (could have been painted) and turn signals. I don't know much about the KDX pedigree other than the fact that it fits what I'm after.
If anyone has any further info on this please educate me. If it is truly identical in all other respects I am going to machine a flange to use the existing stud pattern with the exception of adding two ears in the 3 and 9 o'clock positions to accept springs for the expansion chamber. I'll also have to machine that step that the end of the exhaust butts up to about .250" deeper to match the 1569 cylinders dimension. No big deal. Someone tell me if I'm wrong please.
I greatly appreciate any info. Thanks kindly.
I should also add that the valves in the one I received are in great shape so that's a big bonus. Saves a little change as the ones I had were destroyed.
