H-series RM125 shock conversion - Spring question
A service reference
Has thanked: 10 times
Been thanked: 12 times
Curious how you figured out what was the proper spring to use? Did you use the RM spec, KDX spec, something else? If your sag numbers are good for your weight, would you mind posting your weight and the spring you used?
osobad
Post by osobad »
i am 195 with no gear. I run all my springs one rate stiffer with less prelode. I feel this gives a softer ride. Springs get harsher the more compressed they are. So instead of a 5.4 I used a 5.7 . I would just go by the standard chart
osobad wrote:I would just go by the standard chart
Thanks! However, standard chart for which bike, KDX or RM?
6 Riders
Re: H-series RM125 shock conversion - Spring question
Post by 6 Riders »
Standard chart for a KDX....
What year shock is the one that "fits"?
Thanks! Supposedly the '01-'02 RM125 Showa shock if shortened internally 1 inch.
osobad
Post by osobad »
01-02 is correct
