2001 KDX Voltage Regulator, How To Test
Posted: 10:49 pm Nov 29 2015
Greetings folks,
My son and I each have KDX's. His is a 2001 and mine is a 2005.
His lights quit working and I've been trying to trouble shoot the problem.
I have 30 to 50 volts AC to and through the switch. I have 30 to 50 volts AC to the voltage regulator under the seat so the stator is fine. I don't have any voltage to the supply to the headlight.
I haven't checked voltage out of the regulator yet because it has the funny connector and I haven't figured up a good jumper to hook into one side and check what's coming out.
How do I check the regulator? I checked for resistance through it but it just shows open. I checked on the resistance setting and I also checked on the diode setting.
Before I completely cut the wiring harness open, does anyone have any ideas?
I checked the regulator on my bike as well, the lights work fine, but it shows the same thing when checking resistance and the diode check.
Thanks,
Winkel
Thanks,
Winkel
