Running but no electrics
Posted: 10:50 am Nov 08 2015
by Otoko Retoro
My kdx got wet last week and cut out. I kicked it loads till I needed a rest with little luck. Waited 10 mins and it came to life almost instantly burbled and then ran fine.
I presume the engine heat dried whatever got wet.
Its been ok for a few days but got wet again and did the same as above, waiting 5/10 mins and running etc. Last time I rode it I lost the lighting. Still runs fine but no lighting. Took the wires from the stator and the yellow wire to earth reads half a volt.
Took the stator cover off and unexpectedly, a bit of oil came out. This normal? Surely the stator should be dry?
Re: Running but no electrics
Posted: 11:39 am Nov 08 2015
by Otoko Retoro
The stator gasket is just horrendous, its made of a gasket and what appears to be silicone so somebody has previously bodged it. Furthermore the oil inside has red 2 stoke in it, im thinking this gasket isnt sealing properly. Ill post some pictures later. the seal around the crank is good and its nice and dry in the centre. My guess is that water oil grime petrol dirt etc have snook in through the poor fitting bodged seal.
I had a look at the lighting coil, tested the continuity of the yellow output cable to the coil cable and that's fine however the lead that runs to the o ring and is screwed to the stator plate is snapped. So Im saying for now that I've found the problem. Will go to maplin tomorrow and purchase some 18 gauge wire and do the excellent mod Nick posted.
Can somebody please confirm it's meant to be nice and dry in the stator/generator area? I'm looking at the basic electrical design and its no more complicated than my 1959 lambretta which is bone dry in the stator area
Posted: 07:56 pm Nov 08 2015
by ohgood
yes it should be completely dry in the stator area. no oil, no water, just dry. you can seal up the wire plug with rtv to help keep it that way if you like.
Posted: 01:53 pm Nov 09 2015
by Otoko Retoro
Woo hoo, rewired and all sealed up, cheers for the reply ohgood, I dried everything off and got room temp silicone and a new gasket hopefully sealing everything up nicely. Even wired A switch to flick between main and dipped beam. Result :)
Posted: 02:57 pm Nov 09 2015
by Julien D
I'd keep an eye on that. I can't imagine fuel mix getting in there from anyplace other than the crank seal or a defect in the case half.
Posted: 04:03 pm Nov 09 2015
by Otoko Retoro
Well the tap was leaking and the wires from the stator/generator were up against it, I guess it was running down the wire and into the casing. At least I'd like to think that was the answer
. The area directly around the crank seal was clean and bone dry fingers crossed !!!
Posted: 07:05 pm Nov 10 2015
by The Duck of Deseret
Yeah but? What am I missing here? What about the 'wet' problem? Didn't you say that it would not start when wet----but after kicking it awhile and then ---after a pause---it would start? Then you found a broken wire---wasn't that the lighting lead? ------I think I missed something----what was causing the bike not to start when 'wet"? You aren't saying that the oil in the stator was causing it---were you? Sorry I am confused?
Posted: 12:15 pm Nov 11 2015
by Otoko Retoro
That is a good point duck of descent, obviously im having 2 problems here. I'd like to think the issue was the stator getting wet and now the lighting coil has been rewound and the generator/stator gasket replaced and siliconed up, shouldn't get wet any more .....
Posted: 05:59 pm Nov 11 2015
by 6 Riders
Otoko Retoro wrote:Tduck of descent
Posted: 04:46 am Nov 12 2015
by Otoko Retoro
6 Riders wrote:Otoko Retoro wrote:Tduck of descent
Oops the irony of me getting that wrong. Sorry Duck of Deseret.
