Page 1 of 2
No power... KIPS issue???? 2004 KDX220 Please HELP!
Posted: 12:04 am Oct 28 2015
by Letsgofast
Re: No power... KIPS issue???? 2004 KDX220 Please HELP!
Posted: 12:46 am Oct 28 2015
by Jim B
Letsgofast wrote:...it sat in a shed for five years.
Did it run well before he put it into storage? If so, I'd say it's probably something in the fuel system.
Posted: 12:49 am Oct 28 2015
by 6 Riders
I think that you should pull the jug off and clean the kips out and replace any worn out parts. While your in there, make 100% sure that that isn't the stock piston and if it is, replace it. Stock 220 pistons are known to loose the bottom skirt, which could have already happened.
As far as being flat, check that the silencer isn't plugged .
Posted: 12:55 am Oct 28 2015
by Letsgofast
The top end has been done at some point. He bought it from another guy we work with that had is gone through. It ran great the last time he rode it but had loaned it to his nephew and didn't ride it when it came back and went into the shed.
Posted: 01:20 am Oct 28 2015
by Jim B
6 Riders wrote:As far as being flat, check that the silencer isn't plugged .
Letsgofast wrote:I then removed the power core 2 silencer and verified that it is not plugged.
Reading comprehension, it's a very important thing.
Posted: 01:21 am Oct 28 2015
by Jim B
Letsgofast wrote:It ran great the last time he rode it but had loaned it to his nephew and didn't ride it when it came back and went into the shed.
Ouch...
Posted: 05:58 am Oct 28 2015
by spl383
Jim B wrote:Letsgofast wrote:...it sat in a shed for five years.
+1 I would clean the carb/jets again
Posted: 06:20 am Oct 28 2015
by Tedh98
That missing tooth on the gear would concern me. That isnt soft metal and teeth just dont fall off for no reason. My guess is something jammed and broke the tooth.
I agree on pulling the head and cleaning the KIPS out. At the very least you need to find and remove the missing tooth.
Posted: 06:25 am Oct 28 2015
by Letsgofast
spl383 wrote:Jim B wrote:Letsgofast wrote:...it sat in a shed for five years.
I've had the carb off and cleaned 3 times. I have thought about a 4th but that seems like overkill.
Posted: 06:27 am Oct 28 2015
by Jim B
Tedh98 wrote:That missing tooth on the gear would concern me. That isnt soft metal and teeth just dont fall off for no reason. My guess is something jammed and broke the tooth.
That's a really good point.
Posted: 08:51 am Oct 28 2015
by ohgood
Letsgofast wrote:.....
I've had the carb off and cleaned 3 times. I have thought about a 4th but that seems like overkill.[/quote]
while seeing a chipped tooth on the rotating shaft's gear isn't good, it shouldn't matter so long as you've verified the kips is actually changing with RPM increases/decreases. it's definitely a sign of something going wrong at some point, but the actuation of the system today should prove that it's in working order. verify that the subvalves open and close as you turn the shaft (disconnect the vertical shaft FIRST) and know that the nut on the VERTICAL SHAFT's END is a left hand thread. support the shaft while removing that LEFT HAND THREADED nut, or it will break in process.
pull the reed box-> it's between the carb and head, about six 8mm bolts hold it in place. my kdx ran very poorly once, and one of the reeds was actually laying in the reed box, along with it's phillips head screws. it would start, idle poorly, and pull enough to get me up/down the driveway, but it was extremely weak with that one reed petal missing ;-)
replaced the reed, loctited the screws, and it pulled great again.
you've verified the arrestor and carb are clean, check the next points as mentioned above. :)
Posted: 09:23 am Oct 28 2015
by Letsgofast
I have had the reeds out. They looked great.
Posted: 09:26 am Oct 28 2015
by Letsgofast
ohgood wrote:Letsgofast wrote:.....
you've verified the arrestor and carb are clean, check the next points as mentioned above. :)[/quote]
What are you referring to by "sub valves"?
Posted: 09:29 am Oct 28 2015
by Tedh98
Letsgofast wrote:What are you referring to by "sub valves"?
These:
Posted: 09:58 am Oct 28 2015
by Letsgofast
They move freely but do not return to fully closed as seen here. Could this be the issue?
Posted: 10:25 am Oct 28 2015
by ohgood
Letsgofast wrote:They move freely but do not return to fully closed as seen here. Could this be the issue?
can't tell from the photo which way they are turned, but yes, you want full open/close action on the subs. it will impact low (and high) power of the bike dramatically.
it would be a good idea to pull the cyilnder off, seperate the head, and clean everything thoroughly. i know it sounds like a PITA, but it's really only a few hours work the first time, after that, two hours tops. it will help you verify that everything is moving FREELY and not about to grenade.
the subvalves need to move freely, and FULLY.
Posted: 10:39 am Oct 28 2015
by Tedh98
Letsgofast wrote:The top end has been done at some point. He bought it from another guy we work with that had is gone through.
Aside from getting the KIPS cleaned and working correctly, I would want to pull the head/cylinder to verify that a
Wiseco piston was installed.
Posted: 09:45 pm Oct 29 2015
by Letsgofast
Pulled it apart tonight. Took about 30 minutes as I already had the tank off. Looks like a stock piston. Main valve is so covered in carbon that it barely moves. I'm going to order a service manual, clean it up, and throw a piston at it.
UPDATE
Posted: 10:09 am Nov 06 2015
by Letsgofast
She is up and running. I have to say that a service manual is very valuable in putting the top end and KIPS back together.
Come to find out, the KIPS valves were installed backwards by the dealership(see photo above) that did the last top end. I gave it a good cleaning, installed a wiseco piston, and reassembled. It runs great. I would have to say that there is no way that the bike ran properly when parked. Iboearned quite a little bit about 2 strokes and really like the KDX after working on it and riding it around a little bit. I don't know that I would give up my KTM to have one but the KDX appears to be a serious weapon in the woods.
UPDATE
Posted: 10:41 am Nov 06 2015
by Jim B
Letsgofast wrote:I have to say that a service manual is very valuable in putting the top end and KIPS back together.
IIRC, the manual is wrong and if you follow the directions in the manual they'll be backward.
