Rmx cdi question.
Rmx cdi question.
Guys, ive tested my cdi and compared to manuals ohm specs...on all pin to pin tests my readings are all extremely high or extremely low in comparison. Not sure if that means my cdi is faulty...the bike still runs....just no power under load. On another forum a member said i cannot ohm test cdi...must be a diode test. But my manual doesnt give diode values. Thoughts? Maybe if someone has an extra floating around that I can use on my bike to rule the cdi out that'd be great. Thanks in advance.
- Jaguar
- Country: Ecuador
Rmx cdi question.
If it runs then why are you looking at the CDI? You should be looking at all the other stuff.
Rmx cdi question.
Because ive been through all the other stuff. Kill sw, Coil, stator, carb, mechnical. So by your comment a cdi is either bad or not, nothing in between?Jaguar wrote:If it runs then why are you looking at the CDI? You should be looking at all the other stuff.
