Clutch shaft bearing replacement
Posted: 05:20 am Sep 20 2015
Hi there. Only new to this site and a fantastic resource to have available for the average punter.
I was in the process of replacing the shift shaft mechanism on an old 2000 kdx recently purchased and found loads of chewed up metal in the bottom of the crankcase. After removing the clutch i could see the clutch shaft bearing housing had broken apart. My question is do i have to split the motor to get the bearing out or is there some way to pull it out without splitting the motor? Thanks in advance for your help. Cheers.
