Flywheel compatibilty- Help!
I have a 1986 KDX200. Just wondering which flywheel is compatible. I would have to modify the stator plate slot locations I believe. I remember reading a post that someone used an H series flywheel. Would a flywheel work from a 89-94 KDX200? Thanks!
- doctord23
Re: Flywheel compatibilty- Help!
86 to 88 only.
An H-series can be used if you modify your stator plate.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
What years are H-series? Are the KDX 89-94 the same? Thanks
- doctord23
H-series = 1995 - 2006
Can't tell you if the E-series flywheels are the same as the H, but I doubt it.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
H and E series flywheel are a different part number. I don't know off hand if one can be swapped with the other.
Thanks for the info guys... A friend of mine is giving me a flywheel from an E series. I'm going to see if it will work and get back to you....
"E" series flywheel works with Fredette modification.
