Page 1 of 2
Is that a stock piston in my kdx220??
Posted: 08:17 pm Aug 10 2015
by mtaylor
The only markings I can read is a capital letter A.
Without pulling the cylinder off, can someone tell me if thats an oem piston or a wiseco or a ???
Posted: 08:23 pm Aug 10 2015
by Adamnb1
I think that's oem. They had a b and c markings.
Re: Is that a stock piston in my kdx220??
Posted: 09:30 pm Aug 10 2015
by mtaylor
Impressive if its oem - the bike is 10 years old and hasnt grenaded.
I ordered a wiseco, so ill pull this one out soon and see if its cast or forged.
Anyone else care to guess if its oem/aftermarket? :boogie:
Posted: 09:39 pm Aug 10 2015
by Rippin_RobMX
i would guess that its oem and what is that green stuff in the top right of the top picture?
Posted: 04:09 am Aug 11 2015
by Tioli
I'm going to go forged.
I think I remember they don't like to machin cast Pistons because of the crustal structure. Cast have a outer layer which is most of its strength. That piston looks like it's machined to shape which is not as important to forged as the structure is the same through out.
Could be wrong
Posted: 07:56 am Aug 11 2015
by mtaylor
nL_Devv wrote:i would guess that its oem and what is that green stuff in the top right of the top picture?
paper towel shoved into the water port
Posted: 08:44 am Aug 11 2015
by Rippin_RobMX
That's What I was thinking but it looked weird. When is your new piston supposed to arrive?
Posted: 09:49 am Aug 11 2015
by mtaylor
This pic really firmed my belief this is an oem piston:
IMAGE DESCRIPTION
stock 220 piston one letter and an arrow
http://www.kdxrider.net/forums/gallery/ ... age_id=413
New piston in a week or two
Posted: 12:03 pm Aug 11 2015
by kx200
I got 7500 miles out of my stock 220
http://www.kdxrider.net/forums/viewtopi ... 1&start=20
Posted: 04:01 pm Aug 11 2015
by canamfan
I think it's oem if you look under 220 piston photos you'll see pics of my stock and aftermarket piston. I also see a lot of tiny dings in the top of your piston that I don't see in mine. Those are usually caused by con rod bearings coming apart or something that passed thru the intake and pounded the top of the piston. Like sand getting by the airfilter.
Posted: 07:19 pm Aug 11 2015
by Rippin_RobMX
mtaylor wrote:This pic really firmed my belief this is an oem piston:
IMAGE DESCRIPTION
man not riding for a week or two sucks lol
Posted: 09:31 pm Aug 11 2015
by mtaylor
Not riding for a couple weeks would suck,
thats why its good to have options.
Posted: 12:32 pm Aug 12 2015
by IDRIDR
Here's the stock piston from my '03.
Posted: 02:11 am Aug 13 2015
by Tioli
Well looks like I'm the only one that guessed wrong. Only solution is to stick my head back up that dark spot under my tail and crab walk home.
Posted: 07:42 pm Aug 13 2015
by mtaylor
HOOLLY SHIEEETT!!!
I was too early to say "Impressive if its oem - the bike is 10 years old and hasnt grenaded."
I pulled the cylinder off today and daaaaaamn that piston its trashed!!
How is it that the bike still runs?!?!
There must be bits of aluminum scattered and embedded throughout the bottom end, just look at the connecting rod... :blink:
Sure am glad I pulled this apart, but really how much more damage could have happened, its already faaked.
The piston rings sure are effing loose tho.
Posted: 08:15 pm Aug 13 2015
by canamfan
That's where all those little marks on top the piston came from
Posted: 06:34 am Aug 14 2015
by Julien D
That bottom end really should be split now. You'll never be sure you got all those bits out otherwise.
Posted: 06:43 am Aug 14 2015
by Tedh98
Julien D wrote:That bottom end really should be split now. You'll never be sure you got all those bits out otherwise.
Definitely.
I once tried flushing a bottom end. I lost track of how many times I flushed it. The last couple of times the solvent came out clean. I sat there and looked at it and thought I couldn't fully trust that it was clean. Split the cases and found debris still stuck between the bearings and seals.
I'm sure the engine spinning at 8,000+ rpm would have dislodged that stuff though.
Posted: 07:12 am Aug 14 2015
by Rippin_RobMX
Wow as if the bike still ran
Posted: 08:31 am Aug 14 2015
by ohgood
mtaylor wrote:HOOLLY SHIEEETT!!!
that's impressive damage, but more impressive that it still ran instead of spitting pieces out with each revolution.
good call on pulling it apart, and more testimony to the need for replacing stock 220 pistons.
