KIPS Valve Questions
Posted: 01:05 pm Aug 06 2015
by Rippin_RobMX
Posted: 06:10 pm Aug 06 2015
by Adamnb1
Well, it appears by the gear and rod position behind the slotted cover that the main kips shaft is in the idle/shut/below6000RPM position, and indeed you can see the exhaust slide valve is down all the way (it looks that way, anyway). It also appears that the two sub port valves are closed, meaning that the path to the Halmhotz Resonator is open. So.. I'm no expert but the setup appears correct to me
Posted: 06:49 pm Aug 06 2015
by Rippin_RobMX
Adamnb1 wrote:Well, it appears by the gear and rod position behind the slotted cover that the main kips shaft is in the idle/shut/below6000RPM position, and indeed you can see the exhaust slide valve is down all the way (it looks that way, anyway). It also appears that the two sub port valves are closed, meaning that the path to the Halmhotz Resonator is open. So.. I'm no expert but the setup appears correct to me
ok thanks! And turning the air screw to 2 turns instead of 1.5 fixed the bogging issue. And I'm thinking of using amsoil interceptor instead of yamalube as amsoil is fully synthetic and I don't beleive yamalube is.
