Boot where throttle cable attaches to carb?
MistrRoboto
Post by MistrRoboto »
Hey fellas,
The boot on the top of the carb slide/needle/end of throttle cable is ripped. Looks to be attached to the throttle cable. Can this be picked up separately, or is that just part of the factory Kawasaki throttle cable on a KDX200?
Thanks!
Jim
Re: Boot where throttle cable attaches to carb?
Part of the throttle cable.
Tedh98
Post by Tedh98 »
Don't buy an aftermarket cable, the boot won't fit properly.
Carb boot comparison
MistrRoboto
Perfect. So I just need a stock, Kawa throttle cable to fix it.
Thank!
Jim
Corey
Post by Corey »
Wow what timing. I was about to pull the trigger on getting a Motion Pro throttle cable because I have the same problem. Thanks Tedh98!
Corey
Post by Corey »
What about the Motion Pro clutch cable? Any problems on fitment?
6 Riders
Post by 6 Riders »
Corey wrote:What about the Motion Pro clutch cable? Any problems on fitment?
Nope, but the stock cable is a better cable and only a few bucks more.
MistrRoboto
I am having trouble figuring out the exact part number. Local dealer says this would be "54012-1485".
The frame is a 2001 KDX220. The motor is a 1997 KDX200. Any clue what part# the throttle cable for this application would be?
Thanks!
Jim
MistrRoboto
Again - needing replacement due to torn boot where slide/needle meets carb.
chippy
Post by chippy »
54012-1485 is the correct part number.
6 Riders
Post by 6 Riders »
You can't just buy the boot. You have to get the whole cable.
