How to quieten a expansion chamber
Posted: 04:31 am Jul 04 2015
by Tioli
I love the sound of a twostroke but my ears don't anymore. This is how I quietened my aftermarket pipe to the same level as a OEM double walled one.
It took a few goes before I figured out how to apply it and now I'm happy enough to say if you have the need it can be done.
It starts half way down page 20 and evolves to page 23 (sorry about the stuf in between)
Link to page 20
http://www.trials.com.au/forum/viewtopi ... &start=380
Trials.com.au, forum, all about me, my long time friend the prancing horse
Thanks
Tioli
Re: How to quieten a expansion chamber
Posted: 02:32 pm Jul 04 2015
by Jaguar
When I first put a new ProCircuit pipe on it sounded like someone was banging together pots and pans, but then that slowly died away as the inside of the pipe got its normal layer of soot.
I raced thru your pages but didn't catch what the two materials were that you put on the pipe.
Posted: 04:55 pm Jul 04 2015
by Tedh98
Great job on trying something new.
But I have to ask- if you were wanting to quiet things down for your own ears, why not just use earplugs? About a 1/3 of the guys I ride with use them.
Posted: 05:43 pm Jul 04 2015
by Tioli
The material is called Megasober D10. And a home made carbon fibre Kevlar weave guarde. How I made that is some pages earlier.
My ears ring all the time so am very conscious of preserving what I have. I use moulded ear plugs but MX helmets are more open at the bottom and sound is more bone conducted.
This is not a path I wanted to go down its nesesity dictated the need.
Your clutch is on the list Tedh98 and your ignition is not un-noted Jaguar.
Posted: 06:59 pm Jul 06 2015
by Deseret Rider
After all was said and done----is the bike radically quieter now? ( I went riding yesterday with my son whose 200 with stock exhaust is much ---way more---quieter than my 220 with aftermarket expansion chamber and FMF muffler. So I am wondering if a similar project on my 220 would make it as quiet as my son's 200? What do you all think?
Posted: 07:48 pm Jul 06 2015
by 6 Riders
Use a stock silencer for quiet, they are much quieter that the fmf units, but heavier, performance doesn't suffer either.
Posted: 10:27 pm Jul 06 2015
by Tioli
I run a straight through silencer with the tip pointing to the ground about a meter behind me. That works ok as a silencer. The chamber sounds similar to my mates OEM doubled walled RMZ250. The ting ting ting is gone.
The lining will hold the heat in similar to a OEM pipe. For 220 it will mover the tuned length towards topend. How far is difficult to predict and may not be a bad thing. One of those .5 mm torque rings may be all you need to compensate. I went a bit more than .5 but that was because I wanted to as I have a desert pipe on a 200 with more than enough topend.
So far mine is the only one like it and my motor is not standard so it's all experimental.
Posted: 03:48 pm Jul 07 2015
by fuzzy
The stock pipe is a tractor....I love them.
Posted: 08:23 pm Dec 15 2023
by Chuck78
Wow... Tioli, your hybrid build documentation and engine building attention to detail and small but significant mods everywhere is incredible and enlightening! I will have to give this a good heavy winter read here next month and take notes, before I split the cases on my '99 220 to build it up fresh...
