89 KDX200. Shifting into 2nd is TOUGH! Is it the gear?Fork?
Posted: 09:17 pm Jun 24 2015
Hey guys!
I was gifted (a Buddy passed on) a KDX200, 1989, and with a little patience I got it running and riding! The only problem it has is that it''s hard to shift into 2nd. At a stand-still, I can hold in the clutch and reach down and pull the shifter up and attain 2nd - and it'll stay there. Easily shift to 3rd, 4th, etc... IF I start in 1st, and then pull in the clutch, I can eventually get 2nd (it seems that there can't be any friction on the gears - like the motor is revving right between up and idle). I've never fooled with gears nor splitting the cases but I Imagine that this has to be something to do with either the gears themselves or the shifting forks. Would you more "seasoned" Vets give me a bit of advice on what the probable culprit is? Sometimes, trouble-shooting involves looking at the obvious or most common reasons for the failure, and then systematically delving deeper. How should I attack this problem?
Thanks for any help!!!!
KXDude4
Scott
KXDude4
Scott
