Titling help!
Titling help!
Hi everybody, I have a 92 KDX 200. I'm trying to get a title in Pennsylvania and I'm not sure what process to use. I've ran the VIN in a online service, its not stolen, and I've called the PA DMV to run it and its not in their system. Is there any way to do a multi-state search, and if it was in a state where it wasn't titled can I apply for the title? The other possibility is doing an abandoned vehicle title, but its a little bit more work which I'm willing to do if it depends on it. Thanks guys!
Titling help!
Can't offer specific help as each state is different.
I would recommend you do a search here on this site. There have many posts and threads on this subject. There appear to be many routes to titling a KDX.
- KDXohio
Re: Titling help!
In ohio i was told i can have an out of state inspection done which is free at my local dealer then take it too the bmv and they'll issue me a title since its never been titled.
Titling help!
Railinandnailin wrote:Hi everybody, I have a 92 KDX 200. I'm trying to get a title in Pennsylvania and I'm not sure what process to use. I've ran the VIN in a online service, its not stolen, and I've called the PA DMV to run it and its not in their system. Is there any way to do a multi-state search, and if it was in a state where it wasn't titled can I apply for the title? The other possibility is doing an abandoned vehicle title, but its a little bit more work which I'm willing to do if it depends on it. Thanks guys!
I don't know if your state will allow you to title a dirt bike or not, but South Dakota will, for around $45:
http://supermotojunkie.com/showthread.p ... r-ANY-Bike
I did it in alabama, no problem. tag takes around 5 days (whatever mail speed is) and title about three weeks.
if your state requires an inspection, put lights/blinkers on it from another bike, and pass the inspection. no biggie.
