'08 KX65 front brake issues
Posted: 06:26 pm May 09 2015
I just had the fork seals replaced on my boy's new to him KX65. The brake pads needed replacing in a very bad way, not to mention I'm sure they have been coated in fork oil by the previous owner. I picked up a set of Tusk pads and tried to put everything back together this afternoon. Didn't go so well. I am not able to slide the wheel into place because there is not room for the brake disk. I pushed the piston back in but that is not the problem. There is a "raised" portion of the caliper itself that does not give enough clearance between that and the inside brake pad. How do I fix this?
Ideas? Is there something I'm missing here? Don't have a manual for this one.
