kdx220 airstriker setting help
I have kdx 220 the spec is a full fmf exhaust boysen reeds I have a 35mm airstriker carb what pilot jet and main jet would you advise. open air box lid and snorkel removed
I have checked the current settings and it has a 138 main and 38 pilot jet. I e mailed Jeff freddetee and the response was a 42 to 45 pilot and a 155 to 160 main jet.
please advise anyone.
- doctord23
Re: kdx220 airstriker setting help
That sounds lean to me.
It really is a trial and error process based on altitude, temperature and riding type, but if I was to start somewhere, I would start with the pilot in the same range as suggested, probably a 42, and the main in the low to mid 150s. Needle position also comes into play. I would start in the middle.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
- doctord23
I have a very similar setup on my 220 and I ended up at 42, 152, needle 2nd from the top, air screw out around 2.5 turns.
Most of my riding is mountain single track and fire roads. Elevation 2500 to 6000 feet.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
I would keep the airbox lid on & just remove the snorkel for now....( perhaps add some extra holes )
Keep the kdx 220 needle ( mid clip position ) & slide.
42 pilot & 152 / 155 main with the air screw starting point at 1.5 turns out 1 3/4 & go from there.
Well the latest is I have the 1173l needle in on the 2 from the top. 150 main jet and 45 pilot have tried the 38 and a 42 I cannot get it right from idle. I blip the throttle and the revs are slow to return. any suggestions
Try the needle in the mid position & adjust the air screw...
First make sure your float hight is set to spec.
ok thanks for that, I tried the pilot which was in it a 32 but for it to work it was almost turned right in. I tried a 42 which seemed to be the norm no good. I think I need perhaps a 38 and go from there.
32 pilot is definitely too lean....!
38/40 is about right.....you can run a leaner than stock pilot if your main is richer or your needle in a richer setting....I run a 38 pilot in my 220 with a 152 main & clip in the mid position ( at sea level & with a 36mm carb ) my air screw is between 1 3/4 & 2 turns out..... Bike runs well .
38/40 is about right.....you can run a leaner than stock pilot if your main is richer or your needle in a richer setting....I run a 38 pilot in my 220 with a 152 main & clip in the mid position ( at sea level & with a 36mm carb , air box lid on , snorkel removed & 3 1 inch holes added ).. my air screw is between 1 3/4 & 2 turns out..... Bike runs well .
