High idling issue 98 kdx200
Posted: 08:18 pm May 03 2015
The bike: 98 kdx200
The owner(me): 15 year experienced auto mechanic and power equipment including 2 strokes
Here's a quick history on the bike. 2 owners. Both older guys. Never beat on or raced. I bought it from the second owner who had it sitting for many years. Barely ridden. On to the present day. I pulled it out of my shed yesterday. Drained all old fuel and added fresh 32:1 mix with Spectro synthetic. Brand new NGK spark plug. Opened up the fuel valve,pulled up the choke and kicked it over and she fired up and ran. After a minute or two I pushed the choke lever down and she idled really high. Pulled the choke back up and it ran beautiful. I went around the yard a few times then shut it off. Now, besides the fact that I should clean the carb(which I plan on) I checked the air screw. It's only set at 1/2 of a turn out from fully closed. I thought that was odd.
I am friends with the previous owners Son and he stated it always needed to be run on choke ever since his father owned it. Now that sorta leads me to believe it's not specifically just a dirty carb issue but something else. My questions are....Any other ideas besides the possibility of an air leak from intake gaskets,crank seals? Also WHAT Are the Base Carb settings? Air screw,needle clip,float height. So when I remove the carb I can compare those settings to what it currently is. Maybe something is incorrect.
