Need torque specs asap
Need torque specs for clutch basket bolt clutch spring bolts , water pump primary main bolt ( the big one) please riding on Sunday got fix this thanx
Re: Need torque specs asap
Getting book stand by......
My man
- kx200
clutch basket bolt is 65 ftlb
clutch spring bolts 78 in-lb
water pump impelller nut 87 in-lb
Got it , still need clutch spring bolts and the other big bolt on the right of the clutch basket I think it's the water pump primary
IIts two gears that have a key way in it 22 mm bolt
do you see it? T5?
Yes t5
58ft lb
Thank you your the man don't let anyone tell you different
Anytime! Have a safe ride!
THIS is a perfect example of why I love this sight!!!
Lower Triples pinch bolt Torque specs?
Please start a new thread specific to your question instead of digging up a 5 year old one. Thank you.
Locked.
Locked.
