Adding a headlight
JFortner5
Adding a headlight
Post by JFortner5 »
I was at a friends house today and he had a pile of KTM parts laying around. I noticed a complete headlight sitting there he didn't need it and gave it to me.
my original headlight was gone when I bought my bike so I'm pretty happy to have this one.
My old KDX had no headlight switch to turn it on or off. My current one doesn't either, but I assume if it ever did it was removed too. If possible it like to add a switch to be able to turn it on and off, and use the high/low beam.
Here's the new light-
Here's the actual light-
I'm not a fan of painted plastic, but obviously the orange wasn't going to work. I just sprayed some plastidip on temporarily.
Joey
2003 KDX 220R
kx200
Adding a headlight
Post by kx200 »
you will need a voltage regulator to keep it a 12~AC
6 Riders
Re: Adding a headlight
Post by 6 Riders »
It's incandescent, so no regulator necessary (well it needs the stock one). To use the hi/lo you'll need an after market switch. Something like the Tusk switch, there are other brands as well. Those switches replace the stock on/off switch, so you just need to decide what way you want to go.
JFortner5
Post by JFortner5 »
I believe the regulator and everything else is there, just the headlight and tail light were removed.
I thought the red wire up at the front was power and the black ground. I couldn't get it to work like that, so I tried the yellow wire and it lit up.
I thought about getting two switches and hooking them both up to the power wire. Then use one for high beam, one low, and then I could turn them both off. I doubt it could turn them both on with the stock stator though.
Joey
2003 KDX 220R
diymirage
Post by diymirage »
if I remember correctly the yellow wire is the hot wire to the switch, the red wire is the hot wire from the switch to the light
JFortner5
Post by JFortner5 »
Thanks I had no idea they even had a stock switch. I've never seen one.
Joey
2003 KDX 220R
Yep, yellow is hot off the stator, red is switched to headlight , taillight, regulator.
KDXohio
Post by KDXohio »
My headlight is hardwired no switch
That's fine, doesn't hurt anything other than not being able to turn it off lol. The stock switch is on/off only. As mentioned above, if you want hi/low you have to go to an aftermarket switch. If it's just a woods machine no need for hi/lo IMO
rashad
Post by rashad »
Ok... So going off that diagram.. Assuming no switch... What wires go where?
Sent from my VK815 using Tapatalk
Exactly the same as what's there, but eliminate the switch, obviously.
rashad
Post by rashad »
Ok... just for clarification: So I would wire the headlight into the red and black? or the yellow and black? i wired the taillight up normally but it doesnt work.. so I imagine I would have to wire it differently because there is no switch?
rashad
Post by rashad »
Ok I figured it out.. basically just looked a bit harder at the diagram lol. I was confusing myself thinking this bike's wiring was more complex than it is. i wired the red and yellow wires together, effectively completing the switch, which turned on the taillight as well. thanks for all the help, and sorry to thread-jack.
