Hey Folks,
Bought a top end gasket kit and they included the exhaust o-rings. Along with those they also included a copper ring that is the same O.D and I.D as the o-rings. Visited RMC and looked at the exhuast microfiche for a '96 KDX 200H. They have that listed as well. Question is does anybody use this for their exhaust and does it only work with the stock expansion pipe? I have an FMF Gnarly. Thanks.
Exhaust
- KDXohio
Re: Exhaust
Yes pull out the old copper washer and put the new one inat least i still use it with my fmf
Re: Exhaust
Thanks for the reply KDXohio. I'll be installing it. Just curious, what's it's purpose? Never seen one used with my other bikes but this is my first KDX though.
- Has thanked: 5 times
Re: Exhaust
Paper, scissors, rock. Like rock beats scissors, steel beats aluminum(badly), so it is a cushion between steel and aluminum.
- KDXohio
Re: Exhaust
Great analogy!
- offshoretitan
Exhaust
That is a great analogy, Jason.
Corey, the Service Manual also recommends you re-install the gasket and o-rings with a little high temp grease, probably in part because of the movement / wear Jason refers to and it helps prevent exhuast leaks...
- Service Manual exhaust reinstall.JPG (23 KiB) Viewed 1774 times
Exhaust
Usual arrangement is to use new O rings and high temp silicone sealant.
Copper is a common gasket material for engine cylinder heads. Nice thing about copper is you can anneal (soften) it by heating to a red heat. Quench in water or not is up to you; doesn't make any difference.
So, you can take the old copper gasket, clean it off, heat it red, and re-use it.
