Does this kx 250 cylinder look usable?
Actionman
Post by Actionman »
My 2000 kx 250 cylinder had a sizable chunk missing from one of the transfer port bridges. I used a small file and 2000 grit sandpaper to blend the chunk out, but now that particular bridge looks thin. Ive attached pics of both side's transfer ports as a comparison.
Untouched side: Image
2002 KDX 200
Actionman
Post by Actionman »
Damaged side: Image
2002 KDX 200
s10gto
Re: Does this kx 250 cylinder look usable?
Post by s10gto »
As long as the locator pins don't sit the rings there I don't think it will be a issue. Cylinder looks sleeved anyways.
Make sure you clean up the burr in that right port in the top pic.
Actionman
Post by Actionman »
Its a sleeve. Ive sanded out the burrs around that port also. Ill probably use the cylinder until I get a non-sleeved ebay cylinder and get it replated.
2002 KDX 200
doctord23
Post by doctord23 »
I have one from a '99 at home that I'd be willing to sell.
Let me look it over tonight and see what condition it is in and what the bore is.
I'll pm you some pictures later.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
Actionman
Post by Actionman »
doctord23 wrote:I have one from a '99 at home that I'd be willing to sell.
I got laid off from my job last week, so I may end up HAVING to use this cylinder, which is why im worried :) send pics anyway though.
2002 KDX 200
Has thanked: 10 times
Been thanked: 17 times
It'll run.
KDXohio
Post by KDXohio »
hit it with some acid and scotch brite itll be ok
Actionman
Post by Actionman »
I put a ring through it and checked end gap and it looked like it still has a good seal. I chamfered the high spots around the ports and it looks good. Thanks!
2002 KDX 200
