Does anyone know if you have to buy the Boyesen Rad valve replacement reeds or will any reeds made for your specific bike work on the rad valve?
New rad valve reeds are 70$
Other boyesen's are half that
Boysen Rad valve
- KDXohio
Boysen Rad valve
- KDXohio
Re: Boysen Rad valve
Nevermind sorry guys I called Boyesen I didn't think they'd be open yet
If anyone is wondering the same thing no they will not only thing that fits the Rad Valve is the Rad Valve reeds.
- 6 Riders
I'm pretty sure I paid less than $50 for mine. Check OEMCYCLE.COM.
- KDXohio
I found some for 53 after searching the part# on ebay nothing cheaper yet.
- 6 Riders
- KDXohio
6 Riders wrote:Here....http://www.oemcycle.com/Item/product/900025751
thanks, finally ordered the right valves thanks to your post. i have a stock reed block with good reeds AND new reeds sitting on the shelf, useless.
if boyesen labeled their cage as "RAD VALVE " it would have been a lot easier the first go round.
could this reed cage / rad valve information go into a sticky somewhere?
I'm sure a few people have been perplexed when none of their new parts fit.
I'll take pictures as needed.
