rear shock question
A service reference
argclh6670
rear shock question
Post by argclh6670 »
Im in the process of servicing front n rear suspensipn on sons 95 kdx200....i noticed a couple tiny 1mm knicks on shock shaft assumingly from debris flying up and smacking it. Wasnt leaking so i didnt replace head seal just put a new bump stop (crumbling) and new fluid. i then go to shop to have them recharge bladder. But they said if they charged the bladder it would leak out due to the knicks. My question is.... If it wasnt leaking before, just charging the bladder shouldnt make it leak would it??
kx200
rear shock question
Post by kx200 »
remove the nicks with a wet stone and see what happens
Gotanubike
rear shock question
Post by Gotanubike »
Not sure if 95+ and 89-94 use the same shaft but I have a spare shock off an '89 I only needed for a new lower clevis and don;t mind parting it out
1990 KDX200
argclh6670
rear shock question
Gotanubike wrote:Not sure if 95+ and 89-94 use the same shaft but I have a spare shock off an '89 I only needed for a new lower clevis and don;t mind parting it out
yeah, not sure either. Ill do some research...or maybe someone will comment. Price range?
Jaguar
Country: Ecuador
Re: rear shock question
Post by Jaguar »
probably the nicks allowed the pressure to bleed out, so charging it now would just be a waste since it would do it again.
I would just leave it as is unless it is causing a noticeable problem.
argclh6670
Jaguar wrote:probably the nicks allowed the pressure to bleed out, so charging it now would just be a waste since it would do it again.
doesnt the bladder hold the nitrogen? I. Dont understand how rhe knicks would allow it to leak out.
Has thanked: 52 times
Been thanked: 17 times
The nitrogen in the bladder is what helps the seal to hold against the shaft.
Just use a bicycle pump for now to see how it does.
argclh6670
Jason wrote:The nitrogen in the bladder is what helps the seal to hold against the shaft.
yeah, thats what i was going to do. Put some air in, Run it, see if it holds. (I think itll be fine)
You can fill it with high pressure air temporarily with no ill effects, though you will want to switch to Nitrogen for long term (because regular air condenses and changes density with pressure and temp changes). I have used a bike pump to inflate to check and then taken it to the local shop for N2.
KDXohio
rear shock question
Post by KDXohio »
What oil do you guys use in your rear shock?
argclh6670
rear shock question
KDXohio wrote:What oil do you guys use in your rear shock?
Manual calls for (SAE5wt or Bel-Ray SE2 #40) i used Redline lightweight synthetic 5wt from motosport.
I used KYB the last rebuild 7.5wt, but have used Belray as well. Use whatever is available or you have a preference for.
KYB 7.5 wt?? What is the name of that? I have never heard of that, just K2-C.
KDXohio
Post by KDXohio »
Thanks! The k2c is a bit pricey compared to the aftermarket brands.
It is not too bad if you get it from a Kawasaki dealer. It is the original oil in the shock.
Cturbo
Post by Cturbo »
ATF and regular air on my 92. That was 5 years ago.
Sent from my iPhone
1992 KDX 200
2004 KLX 110
2006 SMR 510
My bad, got my fork oil mixed up with my shock oil. The KYB I used last time in my forks, my last shock rebuild was Maxima light 75-390
Cturbo
Post by Cturbo »
Replying the one who PM me:
I have seen no ill effects on using air from a bicycle high pressure air pump. I use the recommended pressure.
Sent from my iPhone
1992 KDX 200
2004 KLX 110
2006 SMR 510
adam728
Post by adam728 »
Dry air will behave nearly identically to nitrogen. Moisture is what causes issues with pressure fluctuation during temperature changes.
KDXohio
Post by KDXohio »
Found a quart of k2c for 22$ so I just ended up using that with a fresh nitrogen charge that old shock feels brand new again!
