2002 kdx 220 rear wheel
Ive got a rear wheel on an 02 kdx 220 that is a mess. Cracked rim and questionable hub. The previous owner has a non kdx wheel assembly on it, i have no idea what it came off of. Can Kx wheels be used on a KDX and if so do i need to get KX spacers? An ebay search has turned up empty for months
- 6 Riders
Re: 2002 kdx 220 rear wheel
With a bearing swap, a KX or RM hub is a possible fit. As far as spacers go, you should measure, just to make sure that you have the correct spacing.
- doctord23
KX wheels from the 1999 to 2002 and possibly earlier interchange if you use the correct spacers from the bike that you are installing it on. 2003 forward has a larger diameter axle.
I swap KDX wheels on my 2002 and 2001 KX hybrids all the time.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
Thanx...now i wanna make sure were on the same page...correct spacers u said...for ex: if i got an 02 KX250 wheel for the 02 Kdx 220, should i buy spacers for the KDX or KX...also, are the axle sizes the same on a KX?
With an 02 KX rear wheel, use your KDX axle and KDX spacers on the KDX frame. I also have an 01 KX/KDX Hybrid and am running the KDX wheel on the KX frame with the KX axle and KX spacers. As long as you use the spacers intended for the correct frame it will work.
