Pipe interchange
Cr480r
Pipe interchange
Will a 95+ pipe fit the 89-94 engine? I have a couple swap ideas and both would benefit from the lowboy pipe.
Re: Pipe interchange
The pipe will fit the exhaust outlet, the issue is fitment on the frame, but if you're doing a hybrid you should be able to work out the mounts fairly easy.
Cr480r
Pipe interchange
I bought the engine for my wife. Been planning to use in a quad... But a 1991 kx125 roller came up locally.. So she might get a dirt bike
