What kx 500 clamps work for the conversion???!!
Smason25
Post by Smason25 »
I have 94 kx 250 front end ready to go for my 2000 kdx 200f fork conversion. Question is I tried to press the stems out had no luck... So I want to swap triple clamps, been reading that the kx 500 clamps are direct bolt on, but for instance would a 95 kx 500 triple clamp work with 94 kx 250 forks?? Any help would be greatly appreciated!!
canamfan
Post by canamfan »
Hopefully you were pushing the stem down thru the triple clamp and not trying to push it from the bottom. There is a lip that keeps it from being pulled thru from the bottom up. It does take a lot of force and heating the aluminum triple with a heat gun helps.
Smason25
Re: What kx 500 clamps work for the conversion???!!
Post by Smason25 »
Yup tried everything to no avail, we were trying to push it through the triple just wouldn't buge
Has thanked: 48 times
Been thanked: 15 times
How many tons of force did you use?
1995 KX500 clamps would work with those forks.
Anyone that presses a stem out, be sure to put something under the clamp near the stem area. Don't just leave the clamp unsupported.
