gas stops flowing when hose is hooked to carb.
Posted: 04:39 pm Feb 11 2015
Went to start my bike and it didn't start. Checked spark, filter and everything checked out. Checked fuel flow with hose off carb, it was fine. Hooked hose on carb, and no flow. Cleaned the carbs, took the jets out and cleaned them. Checked float level, etc.
I put carb back together and forgot to put the float back in, and gas obviously leaked from the over flow tube, so I know without the float, gas goes all the way through. Put the float back in, and I saw gas flowing through the hose. (I have transparent hoses.) Tried to start it, but nothing. Took hose off, still good flow. Put hose back on and no flow. Any suggestions? I even have the cap off as I'm trying to get flow. Still nothing.
I just installed my desert pipe and wanna test it out. :p
