Page 1 of 3
My 220 Duelsport build (Done! With Pic's)
Posted: 11:50 am Jan 01 2015
by s10gto
As most of you guys have seen in my (any plated KDX's Thread) I am going to duelsport the 220. Thought I would start a build thread here to not cludder up the Q&A section.
I started with a 05 KDX 220 with about 12hours on it. In storage since 06.
First got titled and plated with LED brake,tail,platelight.
Next folding mirrors. Not great as mirrors but they make the law happy.
My state you need a chain guard so got one from a KLX. Made a couple steel mounts from kickstand and rear axle.
Keyed ignition ( you guys in other states have it easy LOL)
And not to forget the KDX220 piston issue. That 220 piston has to go.
Got to order the Baja Designs kit, DOT tires ,speedo and then she is ready to hit the trails (without a truck LOL)
Posted: 12:08 pm Jan 01 2015
by s10gto
Added a couple refl's. as my KLX has them.
Posted: 12:46 pm Jan 01 2015
by GI_JO_NATHAN
Nice!
I recently picked up my first KDX. An 05 220 with a plated title. Finally made it to the tag office yesterday and left with the tag. WooHoo!
This bike was apparently DS'd before, but then I guess the last owner took it all off and only used it in the woods. Came with a few parts including some sort of rigged up tail light. I'm working on getting that wired back up. Only problem I see right now is that the pressure switch on the front brake lever is broken, and right up against the hand guard. So I need to figure out what size to get, and fit it all together.
What are you using for a brake switch?
Re: My 220 Duelsport build
Posted: 12:54 pm Jan 01 2015
by s10gto
Sweet!
Got a hydro switch in rear. You can use a electric switch on rear too. The mount for it is under the side cover. As for the front I am using another hydro switch. The baja kit comes with it but they do sell separate if needed.
Posted: 02:39 pm Jan 01 2015
by Postigo
Hi and happy new year!!!
I have a dual sport KDX220 too, it's a fun bike for short trips but on long ones you should be looking to buy at least a DRZ 400.
I have done a couple of mods to make it suitable for street like stator rewinding, dual sport tires, 14/42 sprockets, rich jetting, battery with rectifier, oversize tank and a tusk lighting kit. Here are some photos
The longest trip I've made was at the west coast of the island was a 145 miles trip in one day and was like running a formula car on the the street. The average fuel consumption is 35mpg and the comfortable cruising speed is about 55mph.
Posted: 03:34 pm Jan 01 2015
by Bitteeinit
How can you "cruise" with it? Are you always varying your speed? Driving my KDX on the highway always feels weird... I'm used to cruising on 4-strokes with a constant speed, but on the KDX it feels a bit weird (but fun). I have an SR (so already road ready), but I'm always worried for the piston when I'm driving it on a paved road.
Posted: 04:01 pm Jan 01 2015
by s10gto
Running on the rich side helps. If I am correct the SR is oil injected. With oil injection the oil is controled with throttle but even with no throttle at least you are still pumping. With injection i believe you are on the safer side as far as oil starvation. My wife has a 2000 KE100 factory street ready that is also oil injected.
This KDX will be my trail machine that I will also use around town.
If I was to do a long street ride I got a new Klx.
Thanks for the pic's. HAPPY NEW YEAR!
Posted: 05:04 pm Jan 01 2015
by Postigo
Don't worry about the piston, just put some synthetic oil and she will do the job. About the jetting is better to run the bike on the rich side because it helps with the hesitation at cruising speed and at the same time is an insurance to avoid a lean condition.
Posted: 05:14 pm Jan 01 2015
by s10gto
Postigo wrote:Don't worry about the piston, just put some synthetic oil and she will do the job. About the jetting is better to run the bike on the rich side because it helps with the hesitation at cruising speed and at the same time is an insurance to avoid a lean condition.
Would you hapen to remember what you are running for jets?
I was thinking to increase my main and pilot my 1 size over factory. Runs mint at factory 145m 42p. I am at sea level. Thanks
Posted: 05:59 pm Jan 01 2015
by Postigo
When she was a trail bike she was 38/138 and now 40/142 she is pig rich even with the needle in the second from top position. One good thing is she still have the response of a trail bike even with the 14/42 gearing. Obvious not the low end grunt of the 13/47 but she have decent power to climb some hills and fire roads.
Posted: 06:51 pm Jan 01 2015
by dougt
NICE! I am in Mass also. I didn't think there was a chance to get my KDX on the road in this state. I've got to look into this.
Thanks for the info!
Posted: 07:26 pm Jan 01 2015
by s10gto
dougt wrote:NICE! I am in Mass also. I didn't think there was a chance to get my KDX on the road in this state. I've got to look into this.
I have been following this in hopes it may work for a friend of mine.
http://www.kawasakiforums.com/forum/klx ... lly-42628/
Posted: 07:28 pm Jan 01 2015
by GI_JO_NATHAN
s10gto wrote:Sweet!
Ok cool. I'll look into one for the rear. Not much room on the front.
Edit: You wouldn't happen to have a part number for the hydro switches do you?
Posted: 07:43 pm Jan 01 2015
by s10gto
Posted: 08:57 pm Jan 01 2015
by 6 Riders
I use a hydraulic switch on the rear brake of my bike. The switch is the same for the front or rear. I actually took mine off of the front and put it on the back. For my tail/brake light, I used the stock KDX light and added an 1157 socket and bulb (stock bulb is an 1157 btw) and added the wiring for the brake switch. I also swapped out a hi/lo socket for the front headlight. Bike looks completely stock with the exception of the turn signals and license plate bolted to the fender.
I would buy the Tusk kit over the Baja Designs kit, if for no other reason, to save some $$.
Here is a link to an inexpensive hydraulic switch.
https://www.rockymountainatvmc.com/p/38 ... sin-Brakes That site also has the Tusk Dual sport kit. I think it's about $180 w/o a headlight.
Posted: 09:21 pm Jan 01 2015
by Postigo
I bought the tusk kit new in box from a guy at ebay for around $70 without the battery and it was for a wr450. Then I bought a cheap lead sealed battery for arond $10 and a RadioShack rectifier for another $5. I'm running the tusk light kit with dc and the front light with the factory ac system. It works great and it's also maintenance free.
Posted: 09:33 pm Jan 01 2015
by s10gto
Looked at the Tusk kits but I like the fact everything on the baja kit is on the mask. Battery ,reg.,horn,flasher,ect.all pre wired and ready to go. Also here I need a high beam indicator. The Baja kit has this along with lights that are D.O.T. approved.
Told ya some states have it easy. Mine is just not one of them.
I do auto inspections @ work and its no easier for car/trucks. Perdy much if it isn't factory it Fails!
Posted: 11:37 pm Jan 01 2015
by GI_JO_NATHAN
6 Riders wrote:I use a hydraulic switch on the rear brake of my bike. The switch is the same for the front or rear. I actually took mine off of the front and put it on the back. For my tail/brake light, I used the stock KDX light and added an 1157 socket and bulb (stock bulb is an 1157 btw) and added the wiring for the brake switch. I also swapped out a hi/lo socket for the front headlight. Bike looks completely stock with the exception of the turn signals and license plate bolted to the fender.
Thanks!
I'll take a look.
Posted: 08:58 pm Jan 23 2015
by s10gto
Well I finally got my rear rack in Thanks to HappyTrails! Its for a KLX300. After some tweeking it fit nice. For a added touch and to stop snags I counter sunk the front bolts at the seat.
Posted: 12:40 pm Feb 01 2015
by s10gto
