1984 KDX 200 has a hard time starting when hot?
Posted: 12:37 pm Dec 29 2014
Hello all,
So after having a hard time find parts for the OEM carburetor (VM32SS) I went 2mm bigger with a Mikuni VM 34 carb. The bike starts a lot easier than it did, but every once in a while it seems to have an issue starting when it gets hot. Wife and I were out riding and she couldn't kick it over and get it started. When I pulled the plug it did seem to be fouled up a bit. I cleaned it up with a wire brush and away we went. It also can get fussy without fouling. The plug it has in there is an NGK B9EG, manual says it's supposed to be a B9ES. Not sure if it's a hotter or cooler plug than what it's K range is supposed to be. I'm still playing with the carb to figure out a good jetting set up as it's not an OEM carb. I'm thinking I will have to lean it out. Anyways I'm trying to figure out what is causing the fussy starting when hot.
-Linny
-Linny
