kdx runs like choke is always on
Posted: 12:44 pm Dec 28 2014
by jersey8115
Just bought 2004 200 starts perfect runs good but when you twist the throttle is sounds and feels like the choke is on when it isn't.doesn't have that snap your neck power checked spark plug was black reeds were clean no problems no cracks what could it be
It has FMF exhaust to so idk if that effects anything
Re: kdx runs like choke is always on
Posted: 01:11 pm Dec 28 2014
by jjavaman
Clogged air filter?
Posted: 01:17 pm Dec 28 2014
by jersey8115
How do I go about taking the seat off I just got it
Posted: 01:35 pm Dec 28 2014
by 6 Riders
WELCOME! You have found a great forum and a legendary bike.......
The bolts are at the back of the seat, going through the side panels. Remove those, lift rear of seat and pull back (away from tank).
Buy a new air filter, preferably 2 or 3. Maybe a pre-oiled, like the No Toil, for your first change. They can be cleaned a re oiled a couple times. Have one for a back up, this time a standard (not pre-oiled), practice oiling and "drying" this one.
Also, your jetting is probably off, so be prepared to go through the jetting guide.
Where are you from?
Posted: 01:39 pm Dec 28 2014
by Tedh98
Was the bike doing that when you bought it or did it just start since you brought it home?
Fresh gas?
I would plan on cleaning the carb. That will also give you a chance to find out what jets are in there.
Posted: 01:48 pm Dec 28 2014
by jersey8115
Well I'm from sj Monroe Twp and is there any better brand for the kdx air filters
Posted: 01:58 pm Dec 28 2014
by jersey8115
And also were can I get a jetting guide and what is it
Posted: 02:22 pm Dec 28 2014
by jersey8115
Also do u know what jets should be in there with an FMF power core 2 exhaust and stock expansion chamber
Posted: 03:27 pm Dec 28 2014
by s10gto
160 main and 48 pilot is stock.
Posted: 05:13 pm Dec 28 2014
by 6 Riders
jersey8115 wrote:Well I'm from sj Monroe Twp and is there any better brand for the kdx air filters
Twin Air, Moose and No Toil's "premium" filter. Are [what I consider] to be the best filters. I've had bad luck with Uni filters coming apart after the first wash. The Pro X filter seems similar to the Moose filter, but I haven't used one...yet.
The No Toil Fast Filter works great in a pinch and they can be washed with dish or laundry soap and re-oiled a couple times. In the wet conditions that I ride in I've never had a problem with using them. Last top end that I did, after 5 years of riding, there was no signs of dirt in the intake or cylinder.
Posted: 08:42 pm Dec 29 2014
by jersey8115
Well I checked the carberator all is good air filter good spark plug keeps going jet black and i am running out of ideas but my next best guess is that something may be wrong with kips so any other ideas of what's Wong let me know
Posted: 08:44 pm Dec 29 2014
by Tedh98
What jets were in there? What is your elevation?
Posted: 09:00 pm Dec 29 2014
by jersey8115
Well stock jets are in witch FMF are correct for an FMF slip on
Posted: 09:01 pm Dec 29 2014
by jersey8115
We are at sea level
Posted: 09:08 pm Dec 29 2014
by Tedh98
As has already been recommended, following the jetting procedure will get things set-up properly. I wouldn't rely on generic settings. Even at sea level, I would bet that the 160 main and 48 pilot are too rich.
Posted: 09:10 pm Dec 29 2014
by jersey8115
So what setup would u reccomend
Posted: 09:15 pm Dec 29 2014
by Tedh98
This will do it: http://www.kdxrider.net/forums/viewtopi ... 105&t=1156
If you have a shop close by that has a good selection of jets, then I would get a couple of jets leaner on the main and pilot (like 158, 155 or whatever the actual numbers are). But if you need to order jets, like from jetsrus.com, then I would go at least three leaner because of the time and expense of shipping.
Posted: 01:51 pm Dec 30 2014
by 3j3j3j
Here is a test on the air filters. Pretty interesting. http://haroldbawlzangya.com/air-filter-test/
Posted: 03:48 pm Dec 30 2014
by KDXhopeful
That air filter test is why I bought 2 Moose Racing filters for my sons 05 KDV 200. It's the only test of air filters I have ever seen.
Posted: 05:04 am Dec 31 2014
by 3j3j3j
KDXhopeful wrote:That air filter test is why I bought 2 Moose Racing filters for my sons 05 KDV 200. It's the only test of air filters I have ever seen.
Its the only one I've seen also but it was done well, so I trust it. :)
