Getting ready to do a fit-check on the FMF Gold Series I picked up for the 250. All seems right, up to the point that I go to attach my new elastomer/anti-vibe mounts.
There is no problem with the rear mount...
...but the front mount seems to be off. First, if I line up the shock mount with the "guide rails" on the frame cradle, the bolt point for the chamber is nowhere near fitting. If I grind off those rails, the elastomer piece still sits nearly an inch away from the cradle when bolted into the chamber.
I confirmed that this is the right pipe for the model with FMF, and I've also double-checked the part number for the elastomer piece. The original bike, which came with a crushed FMF chamber, did not have a front shock mount in place.
Can anyone show me pics of your installation if you have an FMF on your 250-D series?
[/URL] [/img]
[/URL] [/img].
