Crank seals?
richied46z
Crank seals?
Post by richied46z »
I just got a 88KDX200 that needs the right side crank seal. I looked at it with the gear off, and it seems like I need to spilt the cases to install it. Is that correct?
Rich
Re: Crank seals?
Hello, and welcome to the forums.
Yes, the case halves must be separated in order to replace either cranks seal. Almost all KDX and 2-stroke KX's are like that.
richied46z
Crank seals?
Thanks Jason. Bummer. I've worked on alot of engines 2 and 4 stroke and most of them aren't like that.
Oh well time to buy some gaskets.
Where do you guys like to shop for these old bikes?
Rich
Re: Crank seals?
ronayers.com for OEM and usually ebay / Rocky Mountain / oemcycle / and others
You may find some gaskets on eBay cheaper than a real store.
