Cylinder prep
Cylinder prep
Hi folks, so just what has to be done to the cylinder to prepare for a new piston/rings? There is a lot of conflicting advice I'm seeing so what have you personally done to your cylinder to get it ready? I was planning on scotch brite pads to give it a good cleaning then the old soap and hot water wash and away I go. Any thoughts would be appreciated.
- Has thanked: 5 times
Re: Cylinder prep
If the plating is not worn out then that sounds good to me.
Re: Cylinder prep
Thanks Jason for your input, the plating looks good as far as I can tell. Time to do some scrubbing!
