Oil dripping from PV rod rubber boot?
Posted: 08:36 pm Oct 24 2014
by AussieKDX200
Hi guys
Noticed on my last ride a fair amount of spooge was dripping from the boot, as pictured:
It was enough to leave a buildup on the engine case below...
Is this something to worry about? Causes?
thanks!
Aidan
Re: Oil dripping from PV rod rubber boot?
Posted: 08:51 pm Oct 24 2014
by AussieKDX200
Edit:
I see someone else has the exact same issue a few threads down!
Some info on how to best check the seal/o-ring would be great. Is it straightforward?
Thanks
Posted: 09:51 pm Oct 24 2014
by throttleout
Yours isn't near as bad as mine. I'm replacing the exhaust valve main shaft seal, and the sub valve shaft o-rings. Looks pretty easy. I'm a novice though....we'll see
Posted: 01:35 am Oct 25 2014
by AussieKDX200
It's bad - I cleaned a lot of oil off the cases after my last ride.
Never an issue before, so I assume the seal has finally let go. Given it's happened so suddenly, is it more likely to be the shaft o-ring or the main seal?
Posted: 07:12 am Oct 25 2014
by throttleout
I'm new to this so I couldn't tell you.
Posted: 07:49 pm Oct 25 2014
by AussieKDX200
Anybody?
Posted: 08:02 pm Oct 25 2014
by Tedh98
I would only be guessing. Just need to pull it apart and find out for certain.
Posted: 09:16 pm Oct 25 2014
by AussieKDX200
I guess either way it's engine out to access everything?
Given the issue is either the main shaft seal or the sub valve shaft o-ring (both on RHS of engine) is it possible to remove these two parts without pulling the head/removing the actual sub valves?
Cheers
Posted: 11:23 pm Oct 25 2014
by Tedh98
The head definitely needs to be removed. Maybe the cylinder could be left on the engine, but I have never tried it.
I would suggest doing this the right way though and pull the cylinder. It is going to be so much easier that you will gladly pay for the base gasket. There is another seal on the other side of the head that you should replace since something on the other side is worn and leaking. And finally, the valves will likely be dirty or gunked up and could use a good cleaning.
Posted: 11:53 pm Oct 25 2014
by IDRIDR
How do we clean the valves?
Posted: 05:12 am Oct 26 2014
by AussieKDX200
Tedh98 wrote:The head definitely needs to be removed. Maybe the cylinder could be left on the engine, but I have never tried it.
You are right - do it once, do it right.
Just a shame to have to rip it apart though, as the bike is literally flawless otherwise. I checked operation of the PV recently looking up the exhaust port, and all seemed quite clean.
Posted: 09:50 pm Oct 27 2014
by 3j3j3j
It was me who had the same problem awhile back. I cleaned the whole powervalve. I suggest taking the cylinder off. If only like another 6 bolts and a whole lot a easier
Posted: 07:07 am Oct 28 2014
by KarlP
I don't think you can get the subvalve shafts out without taking the cylinder off. The frame is in the way.
You also can't get the main shaft out because the KIPS actuation shaft coming up from the lower end is in the way.
When you take that claw gear off the KIPS actuating shaft, be aware that it is LH thread and that you will break something down in the motor if you don't keep that shaft from turning while loosening the nut
