FMF spring and o ring kit for 220?
TAT2
Post by TAT2 »
Seems FMF does not list a spring and o ring kit for a KDX220. Does anyone know what will work?
T
diymirage
Re: FMF spring and o ring kit for 220?
Post by diymirage »
not sure about the o rings (i always one the ones included in the top end kit) but the last time i needed springs i just walked into my local bike shop and they pulled a set from the shelf
i think they were 75MM but im not sure
TAT2
Post by TAT2 »
I am a noob.... so I did not know the o rings came in a top end kit. I may need to put in a Wiseco. I need to check compression still and what piston is in it.
T
Fitterman24
Post by Fitterman24 »
Ebay has springs--even in stainless steel. Just a upper end gasket set has the o-rings. I used a set of o-rings from the local Ace Hardware store. They worked just fine with some high temp silicone.
TAT2
Post by TAT2 »
Is there something else that fits between the pipe and cylinder other than an o ring?
T
