pLease help
Posted: 01:16 am Oct 15 2014
by kdx2oo
Rubber oil fill plug twisted off what's best way to get the rest out. I'd prefer to not take my bike apart
Re: pLease help
Posted: 05:55 am Oct 15 2014
by royadams
I drilled a small hole in mine and stuck a flat headed screw driver in. And backed it out
Re: pLease help
Posted: 06:42 am Oct 15 2014
by diymirage
no experience with rubber, but I would try getting a pick in there, as for of center as possible and try to "unscrew" it that way
the real issue will be how tight it is on there.
worst case scenario you get yourself a knife or a dremel and cut it out in pieces
Re: pLease help
Posted: 07:39 am Oct 15 2014
by Sullyfam
I would either use a Dremel or razor blade and cut a slot in the middle and then use the widest standard screw driver to unscrew it. If using a Dremel be careful not to cut the side of the cover.
Re: pLease help
Posted: 07:41 am Oct 15 2014
by Sullyfam
+1 for royadams suggestion.
Re: pLease help
Posted: 01:45 am Oct 16 2014
dremel, then penny, nickel, etc. and some PLARS
Re: pLease help
Posted: 05:11 am Oct 16 2014
by diymirage
Jason wrote:dremel, then penny, nickel, etc. and some PLARS
a nickel, sounds like it could get expensive
pLease help
Posted: 05:40 am Oct 16 2014
by ICRage42
I was gonna throw a jab at that but told myself to be nice and you did it anyway rofl.
Re: pLease help
Posted: 08:35 pm Oct 16 2014
by diymirage
not sure how I ended up with a reputation of being a cheapskate but I figured I might as well play it
