Bearing removal
Posted: 06:29 pm Sep 27 2014
by Dekon
How do you get the bearing out of the case that you can not drive throught from the other side. Figured since the cases are split, might as well as replace all the bearings and the bushing. Also, what would you recommend from cleaning the inside of the cases? BTW, not only were my crank seals toast, but the main bearing on the clutch side was so bad that it had started to blue from the heat.
Bearing removal
Posted: 07:19 pm Sep 27 2014
by kx200
Bearing removal
Posted: 02:17 pm Sep 28 2014
by Dekon
Thanks, just what I feel like doing, spending another $100 on a tool I'll use once.
Re: Bearing removal
Posted: 03:03 pm Sep 28 2014
by Tedh98
There are some other ideas, but take a look at response #5 in this thread:
http://www.practicalmachinist.com/vb/ge ... es-188905/
I used plumbers putty to get the blind transmission bearing out of my case.
Re: Bearing removal
Posted: 03:16 pm Sep 28 2014
by IDRIDR
Would this work? Cheap, simple, clean. Eat what you don't use.
http://youtu.be/nkRmKWktW70
Re: Bearing removal
Posted: 03:30 pm Sep 28 2014
by Tedh98
Same concept as what I posted above. Bread would have to be one of the last things I would have ever thought to have used. I have heard of people using wet paper towels though.
Bearing removal
Posted: 06:04 pm Sep 28 2014
by Dekon
Thanks guys, I'll give that a shot.
Bearing removal
Posted: 06:43 pm Sep 28 2014
by ohgood
Dekon wrote:Thanks guys, I'll give that a shot.
yes, it will work. a slide hammer is a very cheap thing to make though, and most welders will rig you one up, and weld the cross piece to your stuborn race for $40 or so.
some of the 30" bearings i used to machine / grind bores for had oil grooves ground into their journals. one grease nipple + a mighty badass grease gun = the outer race came out with ease. it's really quite amazing to watch a 300 lb bearing race just lift out of a journal.
Bearing removal
Posted: 04:32 pm Sep 30 2014
by Dekon
Just thought of it, I might try AutoZone for their tool loan, they have a blind bearing puller.
Re: Bearing removal
Posted: 11:30 pm Oct 01 2014
by newbbewb
W.T.F. That is frickin awesome in a really ghetto way.
Re: Bearing removal
Posted: 01:13 am Oct 02 2014
by ICRage42
Yea I would of never of thought of that. Seems to work really well too and no damage to case.
Re: Bearing removal
Posted: 07:41 pm Oct 02 2014
by newbbewb
I'm gonna have to get a loaf of bread for my toolbox now, just to see the look on the guys faces. seriously, I'm waiting to do a clutch on something now just so I can try it.
Bearing removal
Posted: 03:21 am Nov 27 2014
by Tioli
Excellent tip.
Bread huh.
Re: Bearing removal
Posted: 09:27 am Nov 27 2014
by royadams
The problem with that is there are not any sealed bearings in a transmission. I bet the bread will just push out through the bearing.
Re: Bearing removal
Posted: 10:32 pm Nov 27 2014
royadams wrote:The problem with that is there are not any sealed bearings in a transmission. I bet the bread will just push out through the bearing.
not if it is wheat bread
Re: Bearing removal
Posted: 08:43 am Nov 28 2014
by Tedh98
I use this approach on this bearing. But I will stick with plumbers putty, much easier to clean-up.
Bearing removal
Posted: 03:20 pm Nov 30 2014
by Dekon
OK, so just for reference, the puller set fom AutoZone was to large for the KIPS governor bearing and the water pump bearing. Used wet paper towel and a couple of different bolts. Took all of five minutes to get both out. The needle bearing, as shown above in Tedh98's post, I was able to use the puller and heat gun to get it out. Just heat the case, three whacks with the slide hammer and out it came. BTW, clean up of the paper towel was easy, it was so packed together, it came out in one solid lump.
Re: Bearing removal
Posted: 04:04 am Dec 01 2014
wow!
Cool!
Re: Bearing removal
Posted: 10:47 am Dec 01 2014
by IDRIDR
Thanks for reporting back!
